- Feb 28, 2019
- 502
Ugg, I'm an idiot.
A bunch of years ago I acquired a 9A in very good shape. At the time I was a woodturner and used it initially for mostly precision (for wood) small parts and occasional metal parts, mostly brass. The intent from the beginning was to learn the lathe and eventually transition to brass and steel mechanicals. So it's seen a fair amount of use and I've learned how to operate it.
For the last couple of years i've been focusing almost entirely on metal. I've been learning / improving my skills with steel and was practicing on some 1018 which is somewhat difficult to get a great finish on off of the tool (I use mostly hand ground HSS). None of this is that important, however....
I got really obsessed with refining and polishing the finish on a practice 2" bored cylinder and managed to get abrasive grit all over my ways, saddle, wipers etc. Fortunately I realized this the next time I went to use the lathe.
Moving the carriage now sounds and feels like a lapping operation. I'm at the Don't move anything before I clean this up stage.
I've reviewed a bunch of videos on removing and disassembling the carriage and it doesn't look to bad. I expect that I just need to do a deep clean on ways and saddle and to replace the felt wipers. Once it's apart I'll have a better idea.
I don't think (and REALLY hope) that the guts of the apron won't need to be disassembled and cleaned. Looks like I could handle it but way more work than I'd like to take on if I don't need to.
I think the spindle head stock side is also probably fine. I discovered my F-up really soon and the grit probably mostly fell on the ways and worked into the saddle and maybe the carriage.
Feels really stupid - I knew better and just thought it wouldn't be a problem (I've done small amounts of sanding/filling before without issue)
So a bunch of questions and a request for advise.
Should I get a rebuild kit or can I just replace the felt wipers?
All I've been able to find is this KIT I'm thinking that I might as well get it as I may need more of it later. Is there a good source for just the wiper felts?
Should I try to flush out the apron internals while I have it apart or are the a few parts I can remove and clean without full disassembly?
I've had the compound and cross slide apart before, and will do so again and give them a through flushing.
Once the carriage is off, I'm going to give everything I can get to a really good flush clean wipe and oil. Anything I should specifically do while I can? Remember that this lathe is (was?) in very good shape and if I didn't screw something up, it is probably better to just do deep maintenance rather than tear down and rebuild.
I'm just sick over this, the machine has changed my maker life.
-Dave
-Dave
