- Jan 2, 2019
- 6,545
YepUmmmmm.... Wrong thread??
Correct, that is what I meant to say. Mind saying one thing, fingers saying different...I believe that is wrong. For an even number of threads, you can engage on ANY DIVISION. Not anywhere. Have to look at the dial.
Yes sir. Turned chuck the opposite way, leaving....wait a min... I did take it out of gear, but left the 1/2 nut engaged...Jason, all you did was reverse it without taking it out of gear and you got that?
Same result. Maybe just a tiny bit tighter.Jason, all you did was reverse it without taking it out of gear and you got that?
After comparing the pics, they're pretty much the same.Same result. Maybe just a tiny bit tighter.
I have a only couple to a few thou backlash in everything. Saddle is solid.This is beyond me.. you have something seriously wrong, that I am at a loss to figure out. They should be the same.
Your gibs are tightened correct? you should have virtually no play on a new machine on both crossfeed, compound and as well the carriage should ride without a wobble if you press one side or the other (ie twist on the ways.)
