    Dismiss Notice
Lathe Test Bar Storage?
Discussion in 'METROLOGY - MEASURE, SETUP & FIT' started by Uglydog, Oct 24, 2016.
  1. Uglydog
    Uglydog United States Active User H-M Supporter-Premium
    1,096
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    I was doing a two collar test on my new lathe yesterday.
    I'd already leveled her in plane.
    Before I began the two collar test I thought I'd do a tailstock coarse adjust with a mandrel and a .0005 dial indicator.
    I had a bucket of large mandrels that I've been pushing around the shop for a year (got'em at scrap value).
    I'd sorted out the little ones already for a machine job this past summer.
    Remaining were .75-2inch.
    I found a really long one and rolled it on the surface plate to check cylindricity (qualitative).
    Checked out nicely.
    At this point I noticed that this ~1.25inch mandrel was about 18inch long.
    Really long for a mandrel, or at least the ones I've used.
    On closer inspection it was stamped "Test Bar" on the end.
    SCORE!!
    Question:
    Yes, I need to find better storage for all of them....
    Does anyone know if test bars (and mandrels) have "airy" points like straight edges?
    Or, should the entire bar be supported?
    I've hung my camel-back straight edges and horizontal arbors vertically.
    Daryl
    MN
  2. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    2,825
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    i was told hanging is best method to prevent sag or warpage
  3. Uglydog
    1,096
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    Yep,
    That's kinda where I was going.
    Thinking I might bore out a clear 4x4.
    Daryl
    MN
    Ulma Doctor likes this.
  4. 4gsr
    4gsr Global Moderator Staff Member H-M Supporter-Premium
    2,209
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    I would wrap a piece of tool wrap around the test bar before putting in that hole. Maybe even go to the trouble to coat the ID of the wood block with a sealing wax. Minwax maybe? Not doing so could get rust on your test bar. Any chance of another test bar in you collection of mandrels? Ken
    Edit: not tool wrap but VIC paper, I think that'd the correct abbreviation for it.
    Ulma Doctor and sgisler like this.
  5. Uglydog
    1,096
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    4gsr,
    As I'm not excited about drilling a hole in the end of the test bar ;), I thought I'd make a box and hang the box. Coating the inside or sourcing VIC is a good idea. These "mandrels" looked pretty rough when I scored them. Rusty and dirty. They all cleaned up very nicely. Only a few with some pitting. This is the only really long one. I'll hope to check to see if anything else is stamped this weekend. This sure made dialing in the new lathe faster than a two collar test!
    Thank you,
    Daryl
    Ulma Doctor and 4gsr like this.
  6. John Hasler
    John Hasler United States Active User H-M Supporter-Premium
    764
    113
    City:
    Elmwood
    State:
    Wisconsin
    -Return to Top-
    Use a magnet.
  7. Ulma Doctor
    2,825
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    i admit it's a bit low tech,
    but a hunk of good cord , a clove hitch with two half hitches and you have a hanging arrangement that actually gets tighter as weight is applied
    another simpler knot called a lark's head will do the same thing, as long as there is weight pulling on the knot , it will hold.
    maybe even some high test fishing line could be employed for a floating visual effect ...:)
    Brain Coral and JimDawson like this.
  8. Wreck™Wreck
    Wreck™Wreck United States Active User H-M Supporter-Premium
    1,293
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    I work in a shop which currently has 5 lathes, we store test bars by not having any. I fail to see the utility of such a device as the work will be the test bar and account for all tool, part and machine flex in use. If however all of your work is turned in 1 pass this is not an option.
  9. Cobra
    Cobra Canada Active User H-M Supporter-Premium
    330
    63
    Moncton
    City:
    Moncton
    State:
    New Brunswick
    -Return to Top-
    Why always with the attitude?
  10. Wreck™Wreck
    1,293
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    No attitude at all, I try to convey a concept in as few words as possible in order to avoid confusion.
  11. Cobra
    330
    63
    Moncton
    City:
    Moncton
    State:
    New Brunswick
    -Return to Top-
    If it looks like a duck, walks like a duck, quacks like a duck, it is likely a duck.
  12. 4gsr
    2,209
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    Be nice guys! We hate to lock this thread. Everyone has their own thoughts here for test bars. Let's keep it that way!
  13. Wreck™Wreck
    1,293
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    This will get me tossed from this forum I believe, so be it. EVERY PART TURNED IS A TEST BAR , if the part is small at one end and big at the other adjust the machine or your tooling choices.
    A. Duck
    JimDawson and Ulma Doctor like this.
  14. Uglydog
    1,096
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    WreckWreck,
    I respect your perspective.
    Moderators,
    Please don't bounce him....
    While I wouldn't have purchased it, I'm glad I've got the test bar.
    Daryl
    MN
    4gsr, Ulma Doctor and Cobra like this.
  15. Heckle and Jeckle
    Heckle and Jeckle United States Active Member Active Member
    41
    18
    City:
    Earth
    State:
    Georgia
    -Return to Top-
    Maybe I am not understanding the concept of the test bar thing...
    Unless the test bar allows a user to preform static indications for finding the tapper
    Then I would ask, is there a difference, chuck up a chunk of round bar, cut measure and adjust if necessary, repeat until true?
  16. TOOLMASTER
    TOOLMASTER you don't want to know Active Member
    1,046
    113
    City:
    SOMEWHERE
    State:
    Minnesota
    -Return to Top-
    COLD BEER= TEST BAR SUCCESS
  17. The Liberal Arts Garage
    The Liberal Arts Garage United States Active User H-M Supporter-Premium
    114
    43
    City:
    Keene
    State:
    New Hampshire
    -Return to Top-
    Just make a dry pine box, one side opens, ring to hang it out of the way.....BLJHB.
  18. Heckle and Jeckle
    41
    18
    City:
    Earth
    State:
    Georgia
    -Return to Top-
    As to this hanging a test bar up like clothes on a clothes line... I have heard the same bit regarding the storing of cranks.. However I have never seen a before and after measured example... that validates the THEORY, coin toss.
  19. Uglydog
    1,096
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    My scraping mentor has always hung his straight edges, as did his mentors before him.
    At the very least it saves on shelf space!
    Daryl
    MN
  20. John Hasler
    764
    113
    City:
    Elmwood
    State:
    Wisconsin
    -Return to Top-
    Does your test bar have a taper to fit the spindle taper on your lathe?
  21. Uglydog
    1,096
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    1inch on both ends.
    I used it on centers.
    Perhaps not ideal.
    However, it makes it easily adaptable to many different lathes.
    Daryl
    MN
    4gsr likes this.
  22. 4gsr
    2,209
    113
    Victoria, Texas
    City:
    Victoria
    State:
    Texas
    -Return to Top-
    I've done this many times over the years. It's kind of adjusting your machine on the fly! To get the taper out of the part you are cutting on.
    It's not traditional in use as the two collar test method is, but it does work and is quite effective.
    BTW- Wreck, we love you :grin: too much to run you off. Stay as long as you like. We need guys like you on the H-M forum.:)
    sgisler likes this.
  23. gi_984
    gi_984 Active User Active Member
    55
    28
    City:
    madison
    State:
    Wisconsin
    -Return to Top-
    I put sheets of VCI paper in every drawer of my cabinets and tool chests. I also keep those little packets of silica gel to put in the drawers. So far(knock on wood) I haven't found rust on my test bar, gage blocks, etc. My test bar is almost 1.5 inches in diameter and lays flat on a piece of rubber type drawer liner. I might have to find a new storage location. Please let us know the results accuracy wise.
  24. Wreck™Wreck
    1,293
    113
    City:
    Riverton
    State:
    New Jersey
    -Return to Top-
    You just broke the code my man, every part that you turn, mill or grind is a test before the finish operation, turn it, mill it or grind it to your desired finish allowance then dial in the finish size and have at it, sometimes it will finish larger or smaller then ideal, this is what tolerance bands are for.
    If you were to request a quote from a shop for a small round part that will work just fine in use at say 1.000 +0-.005 diameter I would make you hundreds of them relatively cheaply, if however your tolerance band is 1.0005/1.0007 I would be forced to qoute at a MUCH HIGHER price.
  25. Hotbluechips
    Hotbluechips United States Active Member Active Member
    2
    8
    City:
    winchester
    State:
    Virginia
    -Return to Top-
    In my opinion the storage of "a test bar" is pretty basic. Don't damage it, don't let it rust, and don't use it for any other purpose.
    Worrying about the thing bending from it's own weight, while sitting in a toolbox drawer, to me is silly.
    Are you trying to machine to within millionths? This is the hobby machinist forum, not the NIST Laboratory.
    At some point a little voice should whisper, It should be fine for me.
    bigtrev8xl and Cobra like this.
  26. RJSakowski
    RJSakowski H-M Supporter - Premium Content H-M Supporter-Premium
    2,511
    113
    City:
    Barneveld
    State:
    Wisconsin
    -Return to Top-
    For a hanging storage container, a suitable length of PVC pipe, an end cap, a threaded adapter and threaded plug. Screw an eye hook into the threaded plug and you've got it.
    uncle harry, Uglydog and turnitupper like this.
  27. francist
    francist Canada Active User H-M Supporter-Premium
    615
    93
    City:
    Victoria
    State:
    British Columbia
    -Return to Top-
    Some of the larger (read 1" and upwards) masonry drilling bits for roto-hammers and such often come in a nice threaded sleeve like that. Some of them must be close to two feet long.
    -frank
  28. Uglydog
    1,096
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    I like that one!!
    Thank you,
    Daryl
    MN
  29. ddickey
    ddickey United States H-M Supporter - Premium Content H-M Supporter-Premium
    388
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    Daryl,
    Can you explain this. I was under a different impression such that the two collar was for identifying twist in the bed. Not sure what you would use a test bar for other then tailstock alignment between centers.
  30. Uglydog
    1,096
    113
    City:
    Dayton
    State:
    Minnesota
    -Return to Top-
    It's been my understanding that they accomplish the same thing.
    I've had similar results using both.
    However, neither the two collar, nor the test bar replaces the use of a level.
    As always I'm open to correction and redirection.
    Daryl
    MN
    4gsr likes this.
Share This Page
