- Feb 27, 2012
- 158
Hey, I know I've seen this on here somewhere already, but I can't find it.
I just got my PM1340 in, and I am looking for how to mount it and level it. It has two seperate base stands that the lathe bolts to. The lathe it self has 4 bolts on the headstock end, and two blots on the tailstock end, and I think the base is the same. I plan to anchor the bases in to the concrete slab. Are adjustments for leveling done by using double nuts on the bases? So, the bases would be seating on a nut instead of the concrete.
So, it would be basically leveling the bases and bolting the lathe to the top of the bases. I know i need to actually level it by puting the level across the ways at both ends.
Any help would be a great help. I plan to start setting the lathe up this week.
Thanks,
Jonathan
Thanks,
Jonathan
