- Jun 7, 2013
- 10,089
Casters are not a good idea for most lathes, move it a fraction, and it is no longer level or aligned.
Little more than a table - almost 2700#Only pic I currently have of it but I can take some more if you’d like…when I built my welding table I capped the bottom of the legs but I drilled a hole in the cap and welded a nut to the inside of the cap then welded the cap into place…I then welded a bolt to a set of casters that I’d been tripping over in my shop for far too long…yea the casters are overkill and I need to do something with the flanges for appearances but I can level my table by threading the bolt in or out…total cost was a bit of my time cause I had everything on hand…if I needed a whole bunch of extra length I’d put a piece of all thread into it…granted I know I’m talking about a table and your talking about a lathe on a table (at least that’s what I got from it) but you level the top and the lathe is automatically level…
Must be a rather large lathe then…may I ask as to why you want to put one that big on wheels? (This coming from a guy that has everything in his shop on wheels mind you…) is it so you can move it to get it out of the way? If it don’t have to be on wheels you can get scrap steel plate and crib it up…Little more than a table - almost 2700#
Thanks though! If it were lighter, I'd be interested in doing just that.
Never said I did.Must be a rather large lathe then…may I ask as to why you want to put one that big on wheels? (This coming from a guy that has everything in his shop on wheels mind you…) is it so you can move it to get it out of the way? If it don’t have to be on wheels you can get scrap steel plate and crib it up…
Gotcha…I thought maybe your shop was like mine and it was a constant game of tetris making everything fitNever said I did.
I purchased some leveling casters from Amazon to try, both for more height and leveling only. Didn’t work.
