- Jan 28, 2022
- 850
Hello,This carriage stop is mounted underneath and rides with the carriage. The first photo shows the cover over the threads to keep it clean. With the cover removed I can run the 5/8 11 rod out up to 14" and lock, I rather this to a clamp on for the bed rail. It should not be used with the feed, But if I do I stop the feed on the run and finish up feeding manually. It is a solid stop that will not move when I'm finishing off a run of 60 custom lenth rods or any other work. Thanks for looking.
