- Feb 28, 2019
- 502
The continuing saga of my 9A clean up. Just about wrapped up everything to the right of the headstock. Just the tail stock remains.
On disassembly of the tail stock, I found the large very chewed up rubber washer kind of jammed in on the back end of the quill / hole after removing the handle.
Based on descriptions I've seen, it does not appear to be an original part. The small rubber stop washer is still intact around the lead screw shaft (visible in the picture). I'm guessing that someone put the large one in from the front side without removing the handle and it served the same (sort of) purpose of being a bumper when the quill is fully pulled back/in.
What are your thoughts? have other people found this part in a 9 tailstock? Do I need to add to the "bumper" that's still around the lead screw shaft? The existing (expected) one is pretty cracked and while probably still functional, may not be doing the full job.
Right now I'm planing on just putting it back together as is without a replacement large washer that shouldn't(?) be there.
Thoughts, experiences and suggestions please.
Not a big deal if I have to take this apart again to fix/improve it but would like to get back to a running lathe today.
Thanks in advance.
-Dave
Thanks in advance.
-Dave
