- Feb 8, 2014
- 11,144
I would expect that the motor voltage would be zero if there is no torque on the motor trying to move it out of position. When at idle I would expect some jitter in the voltage around zero volts. A digital meter would read + and -.
The ''Sig'' pot would have the effect of adjusting the output by increasing (or decreasing) the effect of the command voltage. This should not be adjusted until you get the motor to actually run.
