- Sep 20, 2019
- 1,333
Note your power switch has positions 1 & 2 (forward & reverse). These positions correspond to the spindle speed plate above it. When you put the mill in back gear (Lever A in your photo, with corresponding 1 & 2 positions - 2 for back gear), the spindle rotation changes from CW to CCW. Turning the on/off switch to #2, reverses the spindle rotation back to CW rotation (the main power switch is simply a spindle rotation reversing switch. With the spindle stopped, move Lever A to 2. If it resists, turn the spindle by hand and it will go into place.Examining my mill today and my appreciation for it grows every time I use it. This is a complex beast of a machine. Lots and lots of learning for a non-machinest like me.
Couple of things still a mystery to me so I'll ask.
The small lever below Lever A engages and disengages the spindle power feed. There are three other levers required to use the spindle power feed - two on the front of the head and one on left side. The two on the front of the head are visible in your photo. The one with the knurled end has three positions. When pulled out, the spindle power feed is downward. When pushed in, power feed is up. When in the middle position, it is in neutral/disengaged. The lever with the black knob in your photo engages and disengages the power feed. The other lever on the left side, not in your photo, has three speed positions. The plate next to is is self-explanatory. If this lever doesn't want to engage, turn the spindle by hand and it will go into position. Note the threaded spindle rod with the micrometer adjustment. You can set this where you want it, and the power feed with automatically disengage when stop contacts it.
I hope this helps. These functions are the same on BP's and their clones.
