Knurling Question
Carbide pins? Dowel pins aren't hard enough?
If the pins are harder than the knurls, isn't that just as bad?
Sorry, Nightwing, but I don't understand. Could you elaborate on that, please?
American tool companies wonder why people are looking for alternatives to their over priced tools!
It appears that most of the US Companies that stuck with producing tools for manufacturing and never dabbled in the consumer/hobbyist market are doing fine. Dumont for example, can't buy their broaches and bushings at home depot I suspect.
A tool that can produce 200 parts per day for weeks repeatably without fail is worth a bit more to the purchaser then a tool that will fail often or make inconsistent product. Another interesting aspect of American companies is that they only do one thing, they rarely use their large R&D infrastructure to develop other products. Not disparaging the auto industry at all, many advances in manufacturing processes have come from auto makers in the past.
Yamaha makes pianos. motorcycles, outboard engines, personal watercraft and small boats.
Honda makes cars, generators, motorcycles, outboard engines, lawnmowers etc.
Hyundai makes ships, heavy equipment, large engines, cars and other products
BMW makes cars and motorcycles
Kawasaki makes motorcycles and Industrial robots
Toyota makes cars and large CNC milling machines under their original name Toyoda
Mitsubishi makes cars as well as excellent machine tooling, inserts and holders.
General Motors makes cars and car loans.
A hard steel roll spinning on a hard steel pin will result in the two parts welding together when one component transfers a bit of its metal to the other part due to friction and heat. The carbide pin is extremely smooth and much harder than the roll, so there is less chance of the parts setting up.
Prasad, I tried to post pics of my knurler before but was unable to do so until Nelson and Robert got to work on the problem. Now it seems to work and I can show you a simple tool I made for my Sherline lathe. It is mounted to the rear of the cross slide and will transfer to my larger lathe by changing the mount. This knurler has produced beautiful knurls in mild steel, stainless, aluminum, brass and Delrin. In most cases, it will create a full-pattern knurl on the first pass if I do my job.
I hope this gives you some ideas if you decide to make one of your own.
Edit: I forgot to add that it will knurl from zero out to 2-1/8" OD and despite having a hex shaped shank on the main screw, it tightens with simple hand pressure. Cost was almost nothing except the knurls - just stuff I had laying around the shop.
