- Dec 25, 2014
- 9
Hello all,
I recently purchased a Dayton 3Z365A Horizontal Bandsaw which seemed well used but in pretty good shape.
It is a much older but similar to this:
http://www.grainger.com/product/DAYTON-Horizontal-Band-Saw-2LKT4?functionCode=P2IDP2PCP
This saw has all metal wheel with a ridge on the backside of the wheel, no tires. When I purchased it the blade would continue to move outward off the drive wheel, but I thought with some adjustment I could get it tracking straight. To be clear the blade continues to move off the wheel and eventually off without cutting and with/without the guides in place. The two wheels were certainly not coplanar, so I adjusted until they were. The blade still came off. I tried just about the whole range of blade tensions and it would come off at all of them. I also tried multiple blades, I'm unsure if any are new/used but everyone of them...same result. All the blades were the same size (1/2") which I believe to be an acceptable size for this unit. I then pulled off the drive wheel to see if it was tapered. I mounted it in a 3 jaw chuck with and found most of the way around it was .001" or less of a taper, but in one section of the wheel around .004" tapered. Would this be enough to cause the blade to work it's way off? Also the drive axle has some play, around 0.02" in and out, and .01" from side to side, could this be my problem? I've played with this thing for a while now and I don't know what else to adjust, and before i go and turn the drive wheel in the lathe and/or pull out the axle (which i'm unsure how to at this point). I figure I would check with you experts, as i'm very new to all this.
Thanks!
Kyle
Thanks!
Kyle
