- Mar 19, 2014
- 2,681
Yes, the machine tags are sometimes an easy restoration. But to get them off is another story. Most of the time they are attached with drive screw fasteners/twist rivets. And those things are not intended to be removable. If you are not careful you can damage the tag in your removal process. I have tried a Dremel with an abrasive disc, worked kinda OK. But lately have found TIG welding a piece of metal on top of the rivet head so you can grab it better works the best for me. This is TIG welding small stuff, you may what to practice first! And try and remove the fastener just after you have welded the thing so it’s all nice and hot. And yes, with this technique, the paint will burn in your welding areas, so keep that in mind...Good Luck.
