- Sep 1, 2023
- 540
I'll keep ya updated, it's definitely been an adventure
If your lathe is working fine with plain bearings I’m not sure that will gain you much. It might be better just saving for your next machine while you use this one to its fullest capability.Also I've got another idea that I want to do eventually I want to buy a slightly newer headstock so I can change it over to the tapered roller bearings, I don't know if that would be considered sacrilege but I would probably end up doing it as long as the spindle that I have in the gears fit in that casing but I do believe that they are the same
I mean for $40 plus bearings for the new headstock I don't think that would be too bad. Besides I plan on using this Lathe for many years to come so might as well upgrade it while I can.If your lathe is working fine with plain bearings I’m not sure that will gain you much. It might be better just saving for your next machine while you use this one to its fullest capability.
John
oh Nubble, that would be my least favored place for it. Anything on the underneath or front side is going to get lots of oil and chips. Overtime it will foul the reader. The back would be better, as less is thrown to the back. The chuck generally spins toward the front, unless you run in reverse. So lots of stuff thrown that way.Well I've got the first Dro rail installed now I'm just in the process of putting the carriage back together and then I'm going to install the cross slide dro.View attachment 488950
Well the guy who sent me the files for this told me that this shouldn't be an issue, but we will see.oh Nubble, that would be my least favored place for it. Anything on the underneath or front side is going to get lots of oil and chips. Overtime it will foul the reader. The back would be better, as less is thrown to the back. The chuck generally spins toward the front, unless you run in reverse. So lots of stuff thrown that way.
Having just cleaned and painted a lathe, I agree 100%. I was surprised at some of the places that were packed solid with chips and hardened oil. Every DRO installation I've seen and used had the scale on the back side of the bed.oh Nubble, that would be my least favored place for it. Anything on the underneath or front side is going to get lots of oil and chips. Overtime it will foul the reader. The back would be better, as less is thrown to the back. The chuck generally spins toward the front, unless you run in reverse. So lots of stuff thrown that way.
