Just acquired K&T #3 vertical
You dont need a matched set of vices, buy a used pair and tweak them , about the only difference you would need to worry about is height.
I saw good used Kurt vives at HGR last week
Yeah, "matched" in my mind meant two vises of the same model. I realize it is possible to order new vises as a pair from Kurt with precision matching for extreme accuracy, I'm never going to be working at that level of precision.
That is fantastic!
I love to see old tech brought back to use.
I am still considering a DRO on my 1916 Cincinnati mill almost as much for the old/new contrast as for the obvious value on a old, worn machine.
My advice: you do not need multiple new vises.
1) Find a great quality used vise with no fancy stuff (rotary table, tilt, etc.) and bolt it down near the middle of the table.
2) Then add a rotary table to one side, perhaps with a mount the same as your lathe spindle for 3-jaw and 4-jaw chucks,
3) leave some table space to the other side for bolting things down directly to the table.
4) maybe add a small 3-4" tilt, swivel vise for them odd-ball projects.
Please keep posting.
That is a beautiful piece of history you have!
-brino
By that logic, I don't *need* this mill. ;) But I like it. My other mill is set up much like you suggest, 6" rotary on one side, 6" vise on the other. The rotary I have for this is a 16" K&T so it isn't tiny at over 300lbs. My lathes are D1-6, sort of a weird mount to adapt to a rotary but I suppose it could be done.
About time to actually try out making some chips with this beast.
Got the new way covers made up and installed. Knee and headstock has been flushed and refilled. The table has been cleaned and stoned. I've powered it up and run it without actually cutting serveral times. There's plenty more I could do to fix it up,
  • New belts,
  • Drain flush and refill the main column reservoir,
  • New way wipers
Are high on the list. But sometimes ya just wanna try a machine out before doing more work on it.
I have a simple cut in mind, I have a raw casting of a 16" straight edge that I want to mill. I've already run it once through my other mill, but with a 2.5" face mill it took two passes to get the width, and I still need to do the angled face. So I'm going to put this to work. But first I need to get my face mill together. The arbor I have is about 0.050 too long so it doesn't tighten down on the face mill. Clamping the arbor in a lathe would be possible but the taper makes that complex, so instead I'm gong to put the arbor into the spindle, and clamp a lathe tool to the table, probably my 3/4"x 3/4" WNMG holder, and run the arbor over that. If that is successful, then I will go on to milling the straight edge.
Progress report in a day or two.
I wonder how hard the arbor is? File test?
Do you have a CBN tool if the arbor is too hard for carbide?
Could a special "C" or "hat" section washer (on the screw side) straddle the .050" extra arbor length?
I would suggest making a washer/spacer rather than modifying the arbor. YMMV
Haven't file checked it yet. Pre-concept stage only so working on this. The problem with the washer concept is that there is a bit of geometry to the underside of the bolt that goes with the arbor. Of course shortening the arbor alone doesn't solve this. I have a lathe or three so turning a complex washer is certainly possible. The lathe is just in the other shop so I'll be doing some running back and forth. I'll be back at the shop with the mill tonight, and will start pondering all of the details at that point. And may have to bring the cutter and arbor back to the shop by the house to have it in hand for the lathe work. New shop hopefully soon, all metalworking in one place.
Hardened arbor, came back and turned a washer with a matching shoulder to register on the bolt. Wish I had a functional surface grinder to get that washer a bit more polished. .Could hand stone it a bit. But darn it, I’m eager to make something happen with the K&T!
To put that face mill and arbor into the mill, I set the assembly on a paint can and lowered the head onto the mill. Because I wasn't strong enough to hold the thirty pounds up one handed while standing on a ladder to get the drawbar started. Then I realized I don't have wrenches suitable for tightening the drawbar, two 1-5/8". So I ordered a couple of those through Amazon for Friday delivery.
Obviously this mill is not going to be the goto mill for most projects! Fortunately I have something in a more manageable size for "run of the mill" projects.
Chips were successfully made! Always fun to make the first cuts with a new machine. Even if the machine is 77 years old.
This was a very light cut, about a .005" depth of cut, .002" per tooth, with a 6" face mill. 385 RPM and 7.25 IPM. Using steel inserts on cast iron, finish was good. Also happy to see the tramming is good, because the only way to adjust would be rescraping the bed or head of the mill.
Minor challenge, the mill is listed as 11/16" slots on the vintagemachinery.org information I could find, so I ordered a 11/16ths hold down kit from Shars. The T-nuts that arrived would not fit. Table measured about .671 for the slots. 11/16ths should be .685. The T-nuts measured .690 - .701 Some work on the Grizzly mill to reduce the T-nuts to .670. Unfortunately 2 t-nuts got munched in the process do to an operator error. Easy enough to make more.
