It's here!
I remember when mine looked that clean, barely! :))
When you lift it on the stand you can lighted the load by removing the chuck and tailstock.
You should be making chips real soon!
Gary
Tailstock is already off, but I can't turn the locking cams on the chuck. They wouldn't move with a reasonable amount of force, so I left it on for now.
@rdfoster
I have an engine hoist as well.
Yes, this is the common problem. Mine was the same way. The lugs loosen with about 3/4 turn in the CCW direction. Once they break free, you might need a few raps with a block of wood and hammer to loosen the backplate from the spindle taper.
Go at it when you've settled-down from the day's heavy activities... It's yours now, you get to keep it and explore it for as long as you want.
Ray
@rdfoster
Good for you Mike! And you've got a good woman too, who would help crank it in the door?? Fantastic!
Thanks for the pics. Helps the people after you when THEY don't know what to do.
I am a pretty experienced machine mover at this point, so I should start posting ideas.
I am moving my new machine in tomorrow! :)
Bernie
As for the stubborn chuck... Please put a protective wooden board the ways under the chuck. Your fingers and ways will love you for it.
Way ahead of you! I read that tip before somewhere... Oh yeah! Here! Don't know what I'd do without you guys. :thumbsup:
The saga is continued...
As it turns out my wife had a dog show to attend this weekend (she breeds/shows chinese crested dogs) so I wasn't able to do more until today (btw she did very well at the show).
I was prepared to cut out the knee wall at the top of the basement stairs, but had a happy discovery. The PO of the house did a lot of the improvements himself, and this back section of the house was added on by him. He was thinking ahead I guess as this wall was built to be removed!
The plan was to add these HF dollys to the bottom of the pallet.
To do that I bolted on an old chain leveler that I used to use for my bush hog and used a post puller to lift the skid onto some 4x4s and then onto the dollys.
The winch is bolted to the floor this time (even remembered to leave room for the handle to swing), ramps were screwed to the stairs, and a platform was added to the landing to make it long enough to support the skid. It was held up by two jack stands set to support it about an inch below level so that we would be able to raise it enough to remove the stands when the skid was in place. In the first pic you can see that we also added a simple ramp to help the skid move down. Unfortunately there wasn't room to make it as shallow as I would have liked.
The ends were removed from the skid to give us enough room and then it was pushed over to the stair landing.
After attaching a safety cleat to the end of that new platform to make sure the skid didn't roll further than intended, and taking up all the slack, we started lowering the ramp. My wife did this in stages using a 6' steel digging bar to let down slowly. This had some pucker factor, but the cleat wasn't even needed. At this point HF's dicey quality reared it's ugly head. The leading pair of rollers snapped off of the back dolly while we were getting it onto the ramp. The bolt used for the swivel failed. These dollys are rated for 1000lb. each, and the lathe was somewhere around 800 lbs. Once again I was able to use the cordless drill to pay out the line.
Halfway down, the last pair of wheels on the back dolly snapped off. Nothing wrong with the 4 screws holding the mounting plate though, so now we have them digging into the ramps. Now I have to feed some slack, go down and left up the back of the skid with a pry bar to let it down the ramp, and start over again. Oil began leaking heavily from the spindle at this point.
My fearless assistant making her way back up the stairs after getting it all the way to the floor. I am told I'm taking her out to dinner as a reward. LOL
IMG_8970.jpg IMG_8971.jpg IMG_8974.jpg IMG_9017.jpg IMG_9016.jpg IMG_9018.jpg IMG_9019.jpg IMG_9020.jpg IMG_9022.jpg IMG_9026.jpg IMG_9027.jpg IMG_9028.jpg IMG_9029.jpg IMG_9030.jpg IMG_9031.jpg IMG_9034.jpg IMG_9035.jpg
Ah, the trials and tribulations of moving a lathe down stairs!
I'm glad that I've never had to do that yet. Never had a basement!
Good deal on the move! Looking forward to seeing the rest of the setup.
Gary
Good job, very good job! Glad to see you do under such controlled circumstances.
Ray
