Yep , I know . We can't get rid of anything until it dies six or seven deaths . Then we'll yank it apart and repurpose the pieces for another project .Motor runs on the first pull... I am not getting rid of it!
That pretty much sums it up. I see that as a plaque in my shop.That's what a lathe is for, to make what you have fit what you want.
My experience has been that most directly coupled small engines usually have tapered shafts while most belt drive equipment use small engines with cylindrical shafts.Many (most?) small engines have a tapered shaft. As much to position the output device as anything. The way I see it, that's what the compound on a lathe is for. For the collar of a larger shaft, if the output hub has the bore capability. That's what a lathe is for, to make what you have fit what you want.
Talk about identity crisis! On the other hand, no accident would elevate past fender bender...even if it totaled.I have one as well... from a pressure washer... I am saving it for something... do not know what, but something... maybe a mini bike with the body from some VW bug fenders that I have...
To make something like this:
