- Dec 31, 2013
- 327
On mine, the previous owner loaded it on the back of my old truck with forks under the bed using his tractor.
https://www.hobby-machinist.com/threads/got-my-first-lathe-a-south-bend-10k.22935/
I took it off with a engine hoist and nylon strapping wrapped around the inside openings of the lathe bed. Take care not to cut the strapping on the sharp casting. Whatever you do, don't bend the lead screw. All up, with cabinet, it should weight a little over 700 pounds. I wouldn't separate the lathe from the cabinet if you can avoid it as with a trailer it should be easy to load and unload.
If you have a few beefy friends you could possible slide it right on the trailer. With mine, I can slide it around on the concrete by myself, with effort.
