- Feb 1, 2015
- 9,641
All motors experience slip under load. A 2 hp motor running at 2500 rpm will theoretically develop 4.2 lb-ft. of torque. The available torque is further reduced by frictional losses in the bearings and pulley system. Contrast that with running at 500 rpm where the theoretical torque is 21-ft. Also, a 1725 rpm motor speed is the speed under load. The no load speed is actually closer to 1800 rpm.
Don't discount the effect of voltage drop due to inadequate supply wiring. My RF30 clone has a 2 hp motor and draws 20 amps at 120 volts under full load.
If it were me, I would get a better idea of the amount of slip experienced. Your motor may be functioning normally. Compare mottor speed with no belts attached, then with the belts but no load, and finally, under load.
