- Dec 3, 2020
- 172
Haven't used my Enco RF-30 clone enough yet to be 100% familiar. Most of what I've done has been larger cutters and steel, so my RPMs have been low-ish. So it's only yesterday that I finally had reason to run it at the highest speed, about 2500 rpm.
It does spin up to that speed eventually (confirmed with a Hall-effect tach) but it takes a couple seconds, and as soon as I start a cut, the RPMs drop. Even a light cut has it slow down a fair bit. Sorry I didn't take notes, but I think it dropped a couple hundred rpm, like down to 2200-2300? I can repeat the experiment if you need more reliable numbers than that. I was using a 1/2" endmill on wood, and not feeding it very fast at all. (Yes I cleaned the mill very well after cutting wood on it.) Not something I plan on doing much of, but I'd like to be able to spin it up like that to mill or drill aluminum with small bits. 2500 isn't even fast enough for some of your smaller drills in alu.
Nameplate on the motor says 2 HP. I got the mill used, but I'll bet this is the original motor. Date on the motor is 2002. Single phase, wired for 220. I've been impressed by how much metal it can remove at slower rpm, like a 3" face-mill with carbide inserts running about 1200 rpm, .050" DOC, it was loud and it shook some, but I didn't notice it slowing down.
Just wondering:
Spindle bearings seem to spin just fine — when spinning it by hand, I don't feel any friction, to speak of. Ditto with the intermediate pulley bearing, plenty smooth.
I've been thinking of converting to 3-phase with VFD. If I do that, should I expect better cutting power at 2500 rpm with a nominal 2 HP motor? I mean, how much power do you guys have, and does it ever seem like not enough? I could throw more HP at it, but I'm sure at some point the bearings and/or the rigidity of the column etc become the limiting factors, so more HP doesn't buy you more milling, would you agree?
So many questions! I'd be happy if someone could tackle any one of those, don't feel like I'm assigning homework.
Thanks
Mark in Seattle
Just wondering:
- How normal is this? Are they supposed to be able to cut at top rpm (at least a light cut) without slowing down?
- How bad is this? Am I burning out the motor if I let it bog down like this?
- What's the most likely cause?
- What's the most likely fix?
Thanks
Mark in Seattle
