- Nov 25, 2015
- 8,313
edit: older thread, sorry.
Your winters are much colder than we have in Northern California.Hi Dan,
Thanks for the suggestion.
Yes, I am familiar with the wire and hook system as it is used at a lot of museums. But my wife vetoed it. In my house the outside walls have the 1 inch thick hard plaster applied directly to terracotta style tile blocks which seem to have a lot of metal oxides in them making them very very hard to drill into. Getting a screw to stay in the hole, requires a harden cement screw. But it works. On the outside of the block are bricks. This makes the total wall thickness about a foot.
Here is a great one watch and maybe shed some light on the situation.As a machining hobbyist and a not-retired person who works long hours often out of town, I think it is safe to admit that I spend more time watching machining videos on YouTube than I do actually machining. Most often in bed when I'm supposed to be sleeping but the ol cranial flywheel can't be stopped.
One thing I notice in (most?) Of these videos is when people bring a drill bit into the work, it lifts up. If I'm not mistaken this means the tailstock is not on center (worn ways?) and the hole will not be straight. But they don't seem to care or ever acknowledge it happening.
I've noticed other things, what I consider to be an odd side effect of the internet: "Trends" in videos I assume are caused by Youtube-educated youtube-instructors perpetuating oddities. Like how so many people refuse to run a bead of weld. Everything is a series of zap-zap-zap like they they're applying concepts from auto body repair to 1/2" plate.
I'm wondering if that's what this drill-lifting thing is, or if it really doesn't matter, and that's why so many people post videos unabashedly showing close-up footage of it happening over and over and over.
Have a think about the quote regarding the 1/32" deflection a 1/4" drill can deflect until it is at least 3/4" in the hole. Is it really possible?Here is a great one watch and maybe shed some light on the situation.
Once the drill has only penetrated 1/8th of the 3/4” lead, it then has two opposing 45 degree arcs, this is now the total possible land contact. The maximum movement now possible once these arcs have been established is now only 0.0014” at only 0.094” deep! This potential movement continues to decrease as the potential land contact increases. Then until only 1/4 of the lead depth is reached ( 3/16” ) two opposing quadrant arcs are formed. The total land contact at this depth is now 50% of the diameter. At this depth the maximum deviation off centre at 0 and 90 degrees is now only 0.001” as the hole is 0.002” bigger than the drill.Absolutely. Not only "possible" but quite achievable if you're not working proactively. Go back to the beginning and look at the white board part. He's not implying that the hole comes out a thirty second oversize, but that the thirty second deflection is how the the hole gets two thousandths oversized. He's going to a bit of an extreme there to make a perfect* hole, but just watching the feed in is required. Drill bits are very imprecise. Most drilled holes do come out with a bit of a funnel on top. And not quite round. And not quite on point at the back of the hole.
* I say perfect, but that's not the case. Any time you think something is perfect, it means you need better measuring tools. Nothing is perfect.
Yes. His approach is on the the pedantic side but it is necessary for precision. Furthermore, he addresses the dynamic nature of drilling a hole. Whether using a hand drill or precision equipment. It's all the same.Have a think about the quote regarding the 1/32" deflection a 1/4" drill can deflect until it is at least 3/4" in the hole. Is it really possible?
