absolutely. on the plywood mock up there is a steel square clamped underneath right now to keep it flat and square.That does seem good. In the metal one, I’d put a gusset on it to stiffen the horizontal.
guessing you didn't read my 1st post in this thread.This "outrigger" mount is obviously a common solution but I'm having a hard time visualizing why the read head can't be attached to the cross slide and the beam mounted to the carriage. That's how I did my x-axis DRO on my mini-lathe. Is it because the cross slide has a large range of travel?
