if you have an old SB9 you know that the cross feed DRO install can be a challenge due to the shape of the carriage and cross feed and the low profile design. this is my take on a vid I saw on youtube. I mocked this up in wood for now to make decisions. looking for input/suggestions. note that this unit would fit atop the carriage next to the cross slide but A. it would block access to the gib screws, B. it would make access to the compound lock screws more of a pain than they already are . C. and maybe most important I would no longer be able to use the follow rest as the mount would be blocked off.
Ist pic is with cross slide all the way forward. the scale will be attached to the cross slide with a small bolt. the other end will glide on the soon to be aluminum fixed plate with a small pc of teflon screwed under it. a bracket screwed to the soon to be aluminum fixed plate will hold the read head stationary. the plywood plate is 7" wide but the alum one will be 6" wide. has to be that width minimum to use the 2 threaded holes in the end of the carriage.
