- Feb 5, 2014
- 198
No picture but i was able to finish the ID plate from the above post. It came out really good as far as resolution and definition. I did not clean my sand paper enough nor did i wait long enough for the paint to be totally dry so i got some build up in the bottom left corner of residue. Actually, it looks like patina. I will probably use this one for the lathe.
I started playing with the gear box and the threading dial. Never have used one so why not. My belief is that you wait till the dial gets to the same number for each pass and engage the half nut there. Did some playing.
Turned out OK but i have a hick-up in my threading. I noticed that every once in a while i would see the chips momentary stop while i was cleaning up the aluminum diameter. When i was threading you could really see the pause.
I think i traced it to my sloppy apron rack & pinion system. This will probably end up in the other thread but i did not re-bush either bores in the apron for the two rack & pinion shafts. I should have. Not sure the condition of the actual shafts either at this point. I also do not know how well the pinion gear should engage the rack.
Basically, each time the handle comes over the top if flops and again as it goes through the bottom. That is causing to half nut to momentarily jump on the nut. This also may be an indicator that my half nut is worn out.
What do you guys think?
