Inspired Build of the Karl Benz 1886 Engine
Well I am back from a short vacation and ready to go to work.
I cut out the cam towers and turned the cam shaft.
I also straightened the exhaust pipe.
Since I don't have the bevel gears yet (slow boat) I am not sure exactly of their dimensions so I will make the towers taller than needed.
I hope to remove 1" off the towers height and 0.750 off the crank shaft end when they do show up. I made the towers now to give me a reference point for the exhaust valve linkage.
The cam shaft is over length also.
Thanks for looking
Ray
Thank you Boswell but there is a lot of just sitting and looking at it until I get an idea of how to continue.
Ray
Ray
I know exactly where your coming from there.
Awesome work.
Beautiful work Ray!
Thanks savarin and David for the kind words
I made up the rocker arm and outboard lever for the exhaust valve.
I didn't have any brass rod for the exhaust pull rod so I made it out of steel instead.
The clevises for the rod ends are brass though.
I really need to have the bevel gears in my hand before I can go any further on the exhaust.
Looks like a late Wednesday arrival time.
Thanks for looking
Ray
While I am waiting for the bevel gears to arrive I thought it was time for some color.
Now painting in Florida can at times be challenging with the high humidity and high temperature things don't always turn out as planed. I painted the first few pieces and was rewarded with a pale pink color. Not that I don't like pink but I was looking for a bright red instead.
I got out the toaster oven and set it at 150 degrees. I found that if I could get the freshly painted item into the oven in under 2 minutes and leave it in for 10 minutes it turned out alright.
Some parts were not as nice as I had hoped but most were fine.
What do you think?
Thanks for looking
Ray
That red is really going to stand out. In a good way.
