If you meant, and I think you did since you referred to TEST indicators, .0001 and .0005 (one tenth and five tenths) then I'll say that I find both useful but for different purposes.Using a .0001 DTI (dial test indicator) for locating the center of a hole for instance is an exercise in frustration. The needle just moves around too much for me. The .0005 is the tool for that job. A vertical DTI is easier to use than a standard horizontal DTI for that task too.The .0001 DTI is the tool to use when you're measuring how flat a surface is, especially when surface grinding.I've never used a DTI that wasn't auto reversing so I'm not sure what the non-auto reversing DTI's are like to use. Auto reversing means the DTI will measure a surface when you touch the bottom of the ball to a surface below it and will also measure it when you touch the top of the ball to a surface above it. A DTI isn't a tool used to measure the size of a part by itself. It will measure small surface variations but to use it to measure the height of a 2" block it needs to be attached to a height gage. You zero it out on the surface plate the 2" block is sitting on, note the reading on the height gage or zero it out if it's a digital HG. You then crank it up a bit over 2" and bring the DTI down onto the block until it zeroes out again. You then read the height of your block on the HG.Many of the imported DTI's will work fine and they calibrate out accurately but I'm not so sure they'll have the longevity of life that a Starrett, Etalon, or B&S will.If I had to choose I'd choose a used Etalon or B&S over a new import.
