- Jan 25, 2015
- 2,558
Another possibility is to buy a replacement mixture screw, look at how deep you need to go to just clear the threads, set up a depth stop and drill right down the center of the stub. Then expand out in drill sizes until you can pick whats left of the screw threads out. The rest should come out easy and you save to orifice in the body.
Drilling right down the center will be the biggest pita. I woukd recommend doing it on a mill so you can fixture the mixture screw absolutely vertical and the mill/quill will also be more precise.
If you do elect to drill it out, know going in that you might very well have to order a new carb body. One slip and……
