- Feb 26, 2021
- 473
Use a torch, or at least a hot air gun. If there is enough nub sticking up, cut a slot in it with a dremel cut off disc. Cutting down into the carb body a little typically isn't a big issue either. Worst case, drill a hole in the nub and then pound in a torx bit. That's safer than using an ezout, which love to break off.
