The soft jaws are in my budget,so I may pick up couple sets.Plus the set that I have which I will kinda practice on for that first special job.Thanks again guys this is fantastic
I often turn very thin section parts for the high vacuum industry, sometimes 10' OD X 1/4" thick with counterbores and O-Ring face grooves and find full circumference jaws (often called Pie Jaws) indispensable for such work. This is a set of 12" Pie jaws on an 8" chuck, I turned a pocket 8 1/2" diameter X .060" deep to hold the part, worked a charm.
