- Apr 6, 2011
- 2,082
As I understand it the weight limit for the Bridgeport table is 750 lbs. so even the largest RT shouldn't be too much of a problem. I personally wouldn't leave it on there for any length of time though. If a job comes through that needs it, mount it to the table, run the job, and get it back off.
As it's way beyond "back breaker" size you have a number of options for lifting it on/off the table. You could make a rolling cart on which you could place the RT, roll it over to the mill, match up the table height to the cart, and slide the RT on/off the table. If it's not going to be used a lot I would just use a shop crane like the one below to get on/off/move it around. (Hint: That "L" bracket attached to the RT was probably used for this.)
2-Ton "foldable" shop crane from Harbor Freight or any other source.
Hope that helps,
-Ron
Hope that helps,
-Ron
