- Oct 5, 2010
- 1,043
What kind of speeds do you run for burnishing?It was suggested that I try the tool for burnishing & it worked!
Here is the video of it bumpng parts true.
The ball assembly is supported internally by Belleville washers that are rated at 12Kg with a 3.3mm deflection. I compressed the washers by 0.35mm for the steel block.How much pressure are you applying. The 1/2" balls I found on Amazon are only rated for 33lbs.
