- Jul 26, 2011
- 4,142
Your drill wandered off center for several possible reasons: Did you center drill the hole first? Was the drill ground freehand a little off center? Was the drill a little bent?(you can chuck the drill by the shank in your chuck and run it to see if it wobbles.
When starting a drill,if it wobbles at all,it will not drill a centered hole very deep. I stabilize drills by putting a blunt ended tool against the side of the drill with the tool post holder as it begins to drill. Carefully push the drill sideways until you get the wobble out of it. DO NOT push it past center. You frequently can find even new,USA made drills that have a bit of curve to them,especially in the smaller sizes,though I have seen 1 1/2" drills that are badly curved. They leave scored sides in holes they drill.
Go read my useful tips listed at the top of this column. It's at the top under "Important threads"(or something like that).
