I'll go buy a few cans of Raid... I can spray the hole from the outside edge of the porch...
Make sure it's the foaming one..... Night and day over those that don't.
I just don't know if I can get enough spray inside the hole to kill the entire nest.
But I'm gonna try...
-Bear
Yes, yes you can. First (and I can't say this enough), get 'em early in the morning, when they're all home. If you don't get the vast majority of them, they'll set up another nest/colony in no time. And again, there's none outside too come up behind you while you do it. That's a big deal. These guys do communicate.
Spray from a modest distance (ten ish feet) hose the main opening they're using, and expect more. When you see movement elsewhere, spray there too. (Foam..... Some of it stays where you were spraying before...). There may well only be one way in, but there's a good chance there's multiple entrances. (Inside the basement maybe?
) After what seems like an eternity, but in reality is a couple seconds at best, you' can approach closer, aim right at the crack, and jam all of that stuff you possibly can inside the crack/cavity.
Further.... Put a sheet, old shower curtain, something inside the basement wall, centered about where that issue resides. If they're coming in, you're not guaranteed, but could probably expect bug killer coming inside as well. It won't be a violent spray by then, and may not be an issue at all, but it keeps it off of things that you don't want to be toxic.
And don't hesitate.... You have to go into it knowing you've got this. If you stay on 'em, don't let up, a whole nest seldom outlasts the spray can. And if it does, I did mention the two pack.... A second one at the ready is cheap insurance. If you stay on 'em... With the foam.... it goes pretty well. They'll still be crawling when the first can is done, but they're not worried about you any more. If you hesitate, stop half way through, or have poor or inconsistent aim with the "not foam"... They'll get by. How fast can you run? Absolutely you need to have a plan for that of course in case of a worst case scenario, but honestly... Before they're awake, when they're all there, and stay on 'em.... It's not too bad.
After that, an hour or two for any "barely sprayed" stragglers to finish straggling, and any survivors to settle back down to their normal peaceful coexisting selves, and it's done.
