In the photo below, you can see what I was doing that did not work so well with a compound. I was trying to put a groove in the welded, beveled joint. That 10.75” OD pipe extends below the cross slide (something that I will have to watch out for so that I don’t cut into my cross slide!).
Since I could get the cross slide only so close to the work, I had to extend the compound. Upon attempting to cut the groove, the extended compound vibrated even though the compound & carriage were locked.
If you’re thinking that a LH boring bar would work, think again because the cross slide cannot be pulled back far enough to use a boring bar. Plus, who puts a grooving tool on the end of a boring bar?
EDIT: after I posted this, I realized that I could pull the cross slide back all the way AND move the T-nut back in order to make room for a boring bar.
In any case, I don’t own a LH boring bar. It would appear that when the workpiece extends below the cross slide, you can only work on the first few inches of the workpiece. I would also like to have been able to part that 4” in.
