- Apr 14, 2014
- 3,185
It's one of those mistakes you learn from. Back several years ago I was making a back plate for a new chuck. At the time my only lathe had change gears. I read the chart, selected the gears, and set everything up for cutting 1 7/16-12 threads. Everything went according to plan, and after several cuts I made a final finish pass. The threads looked like they were straight out of the factory. I was so proud of my self my right arm grew 6 inches just from patting myself on the back. I took the back plate out of the chuck, removed the chuck and attempted to screw on the new back plate. As hard as I tried I couldn't make it fit.
I measured the thread angle and depth until I was blue in the face, but still couldn't find the problem. As a last resort I got out the thread gauges and stuck the 12 tpi one into the threads. Close but no cigar. I measured in several different places with the same results. I went through a number of pitches and finally found the one that fit. It was 11 1/2 tpi. I had inadvertently grabbed a wrong gear and spent an afternoon making a worthless part. To this day I keep the part in prominent view so I can remind myself to double check everything before making a cut.
At the time I had never heard of an 11 1/2 tpi thread and had no idea what it would fit. Just last year I needed to make an adaptor from a garden hose to pipe thread. Guess what, a garden hose fitting is 11 1/2 tpi. You live and learn. Fortunately you made a mistake that only caused a cosmetic blemish. It may have been the first, and hopefully it will be the last.
