I am very confused by a video posted on Youtube to adjust a single jaw on a 4 jaw chuck.
Having looked at the other videos in his channel I am getting a better understanding as to what is going on here. The videos are very well made, the lighting is uniform with background shadows that enhance the image but do not detract. The set is immaculately clean and organized with some items scattered to give the impression of use. You cant find a single chip or drop of oil on that work table. There are graphics to reinforce the narration and the narration is scripted, perfectly timed and overlayed. There are no images of the work being performed only of the finished results. I think the time & effort put into making the video is at least as much if not more than the work performed on the lathe.
I think the lathe is meant to be industrial art, a nice conversation piece. By his own admission he has not used the lathe, the "Franken-lathe" does not have a tool post. It looks to me that this is meant to be pretty and not necessarily functional. Clean the grit and grease, remove rust, polish, paint, replace worn wires and broken parts, clean and clear coat the plaques, cover worn ways with tape. I wonder if we are seeing product placement in the use of Rulon tape.
I think this is meant to be entertainment like "Tool Time" and not a mrpete222 instructional video.
Caster
Hmmmm...
The video does seem to be more 'studio' than 'shop'. :thinking:
I saw a few good points in the video... however I think I would watch a few more (which came from a shop that appeared to be worked in)... before I determined a procedure I was gonna follow. :allgood:
That 'advise of many folks' thing... :)
Forget the lathe and chuck jaws, just use the Dremel rig for sharpening chainsaw blades.
I am surprised no one pointed out the final part of the video. He shows an arbour that he just turned on his now perfect chuck and the video is zoomed in on a nice big bur or some sort of damage to the arbour.
I am sure anyone serious enough about machining to put a video online on hire to perfect your chuck would never dream about showing a mistake like that on their video.
My 4 jaw chuck, (new in box) came with numbered slots and jaws, also came with .007 taper in an inch.
I'm in process of correction. I put a washer in the far back of the jaws, indicated each jaw in the center of its length and ground to clean up. (Air powered die grinder in a boring bar holder) Next phase, after I figure out what happened is to straighten the jaws. when clamping on a round piece I can see daylight between the piece and the front of the jaws. The jaws are a near perfect fit in the slots, no wiggle at all, so I haven't solved the problem yet.
as he somewhat states in the video, the jaws were sprung , contacting work piece closer to the chuck and not touching near the tips so he was squaring the jaws to the chuck not fixing an alignment problem you state this in your post that truing up jaws is a 3 jaw operation. maybe I am misunderstanding . I am new to this sight so don tlaugh at my posts too much thanks bill
also I am not a typist so errors will occur.
We all know Typonese pretty well by now, Bill. That's the last thing to worry about.
As a few have pointed out already, but just to recap,
1) Red tape on ways, Painted Pulleys, Tie wire
2) @0:10 Bench vise "secured" in place by mini G clamps.
3) @1:38 Bolts pressing on (plastic) body of dremel tool to secure it in place
4) @1:55 A tool he has had for "probably 20 years" and it looks newer than the lathe that was made yesterday
5) @2:05 Wood T-nut with grain oriented to split
6) @3:15 Dial indicator measuring to thousandths of an inch but thats ok he can determine that with finger pressure
7) @3:28 screw holes that he drilled and tapped? I dont think so. Not in that conveniently placed piece of casting
8) @4:10 Flex in grinder stickout length. I mean how good is that bearing really? In his 20 yo cheap dremel tool
9) @4:19 Maybe more is being taken off that 1 jaw because the crappy piece of tie wire is not as tight as the other 3
10) @ 4:35 Precise arbor
11) @4:40 Setscrew mark
12) @5:00 Precision ground arbor that was previously secured in aforesaid "wonky" chuck.
13) Plus some others that I'm sure I missed........
All on a lathe that looks like good enough to have come off the production line yesterday. And a brand new chuck to boot. Those jaws arent bell mouthed from use, thats cheap and sloppy dovetails in a cheap and sloppy chuck to locate the jaws.
There is so much wrong with this video...........
I think this is wacky. Am I not understanding?
I don't get it. the error in a single jaw as stated was it was not parallel to the axis of the lathe, not a concentric problem. The correction applied is the method of correcting a three jaw scroll chuck for one jaw being out of true or it is way out of center.
Why would not a grinder run in parallel to the bed against the offending jaw not bring it back into line on a 4 jaw chuck.
This makes no sense to me and if it is correct and I am not I am in big trouble understanding the dynamics and geometry of my lathe. It is possible.....
No
please help a want to be machinist.JB
I guarantee he is not one
This is an instance of where the BS filter needs to be applied. Heavily! I know I'm a mod and we need to be forgiving courteous and gracious, but sometimes we just need to get out the FBH.
Just because its on the internet doesnt make it true
Cheers Phil
I have a chuck just like the one in the video but instead of a 6" chuck it is a 8" chuck. Same lathe, a 9" South Bend Lathe. Dad bought the chuck about the time I was born, late 1950's. It was the chuck I learned on and used for many years in my youth. When I was around 13 years old, I complained to dad about the bell mouth of the jaws and wanted to do something about it. Well like everything else I learned and did from dad, I learned the "proper" way to fix the jaws by grinding them with a preload applied to the jaws, at the tip of the jaws, using a Dumore tool post grinder, which I still have. The jaw fix lasted for a couple of years until the problem just worsen. Finally retired the chuck and put a new 3-jaw in its place. Now that I have larger lathes with nicer 4-jaw chucks, I really have no need to put a 4-jaw back on the 9" SBL. I do have a older Cushman 6" 4-jaw in reserve to use on the 9" SBL if needed that is in good shape. BTW: I've worn out a chuck key on that chuck over the years, never once applied a leverage on the chuck key to make it look like a pretzel! Ken
Ive seen a couple of his videos on "restoring his lathe". I cant imagine the welts I would have had as an apprentice had I called that a rebuild.
Just because someone claims to be a professional, there is no guarantee this is the case
The fact someone does something for a living, or in this case publishes on YouTube, is no indication of their ability
