- Sep 22, 2010
- 7,223
So I have a tiny shop area in my basement, and the ceiling is barely 8 feet to the joists.
Putting an engine crane down there allows me to lift only so high before the arm gets stuck on the 2x10 beams. When I reassemble my Van Norman #12 and have to hoist the 100 pound spindle motor up to the top, and the 200 pound ram assembly, it will not be easy without some hoisting device. Clearly, another solution is needed. But it has to be safe.
I worry that simply bolting a chainfall to a joist by putting a bolt through a joist and hanging the chainfall on it may split or compromise the joist, or weaken it, which clearly I do not want to do. There are also some water, steam, and gas pipes in my shop area on the joists, which makes it more difficult.
I can take some photos of the joist situation above my shop if need be, (perhaps the better idea), to show you what I am working with.
I am looking for a SAFE solution to hanging a chainfall or other similar device to the joists to let me hoist things like the motor and ram high enough to attach to the mill.
Thanks!
Nelson
Thanks!
Nelson
