- Dec 12, 2021
- 82
Thanks for sharing the link. I didn't know about this resource.Hi Spajo , have you seen this guy's ad ? https://www.ebay.com/itm/393570455469?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
I have a new LMS 5100 7" x 16" mini lathe and a Grizzle G0781 drill/mill. My father was a refrigeration mechanic, and I inherited his oxy-acetylene rig and an ancient Hobart stick welder. The welder is 220 and I don't have a convenient place to plug it at the moment.I’m curious, do you have another lathe or access to one that you would be able to do any repair ,either by yourself or free by a friend ? Likewise , for welding ?
I sent him a message, I'll let you know when he has time to respond.Hi Spajo , have you seen this guy's ad ? https://www.ebay.com/itm/393570455469?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
matthemuppet2: That is an interesting idea and yes, the bearing still has some smooth shaft to run on. The gouges do not go all the way around the spindle. I show the gouges in the image, but the other side of the spindle is fairly smooth. The bearing is split and there is an oil hole. I will have to look, but my memory is that the bearing isn't that bad, but there is enough shaft wear such that there is some slack. I might shim the bearing to get it to tighten up. It would not take much - 0.020" or so should work. Nothing lost to give this a try. Thanks for the suggestion.Do the gouges go all the way around the spindle? How much contact area do you have left with the bearing and what does the bearing look like? From memory the bearing part of the spindle goes back to the lip before the woodruff key for the bull gear, in which case you probably still have enough surface for the bearing. I would carefully stone down any raised parts on the worn area and put it back in. Those bronze bearings are pretty long and the gouges will serve as oil pockets
Thanks for the info, especially the part about drilling the Oilite sleeve and slinging oil -- I can imagine that for sure! I know it would be simpler to just buy a replacement spindle, but it is my nature to repair something and I learn a lot even if I fail. The bearing is split by PO, so, I was thinking to put the shim on the outside of the bearing to squeeze it down. I've never tried that. If the Oilite is brittle, then it is clear that won't work either. I reached out to an eBay seller who has a good stock of parts for these machines, I shall soon know what he thinks a spindle is worth.On the subject of shimming, you cannot shim these sleeve bearings. The shim material would have to be inside of the sleeve and there would be nothing holding in in place. My suggestion would be to install new bearings and hope for the best. And it is not necessary to drill an oil hole as a PO apparently did. The Oilite sleeve bearings are all made of sintered bronze and are porous. All that drilling a hole will accomplish is to drastically increase the oil consumption rate and the oil slinging problem. And in case you haven;t gotten that far yet, the original recommendation was SAE 10 ND. In the ;ate 50's or early 60's, Atlas changed the viscosity and type to SAE 20 ND.
Also, do not try to squeeze the bearings smaller by over-tightening the screws. You will just crack or break the casting and scrap it.
The seller hasn't replied to my query so no traction there. If I do hear from the seller, I will follow up with a post. I knew that some Craftsman model(s) had Timken bearings. That would be nice.Good luck Spajo . I under stand you wanting a good challenge and to repair the spindle . To me the challenge would be getting all the parts you need to get the 6" running , looking over that pile of parts (the ebay stuff) I see everything you need . Also I see some 618 head stocks , The 618 has Timken roller bearings (pardon if you knew) . I will be interested to hear about this ebay seller .
Mark .
