...Here is a picture...
I will try that tomorrow.if you stick a little screwdriver down in the hole on the cover, and feel around for the lower, center adjusting screw, is it tight? Can you back it up to push the cover upwards?
I see a gasket in there, I bet it just needs a little "tap" to break it loose. Find something round to stick down that hole, hold it vertical, and tap it left to right. Screwdriver handle taps maybe, not hammer blows...
