- Nov 24, 2013
- 1,791
Yea just move the table over to offset. But your right, if you dont adjust it becomes scrap on the back cut
You could mount the old part on the roto table edge find one side of the slot, Zero the table and rotate to the other side of the slot. Record the angle. replace it with the new part and mill these slots every 90*. MarkI am trying to figure out the angles and how to cut the left and right sides of each notch. I think I should cut the 4 right sides first using an end mill smaller than the narrow end of the slot and then move the table the width of the cutter and then cut the 4 left sides.I do not know how to figure out the number of degrees to rotate the part. I don't have anything to measure the angle with.
