I would start by chucking the stock up in the lathe turn the diam. then center drill and drill the center hole just under size and ream it to final size. from there I would put it on the rotary table and center it. Now take the good part and find center of Two pie shaped slots accross the dia. scribe center and mesure the angle needed. Now you can mill the part. using an end mill the same size as the tightest part of the slot mill accross the dia. of the part. back out and rotate the table to the angle needed, This time only mill to the center of the part. Back out and rotate the part the other way and mill to the center again. rotate180* and repeat the angle cutting steps. Turn 90* and start all the steps again. I hope this is making sense I have a bit of a headache and it has been a long day. I would also check the fit before I removed the part from the roto Table. Mark
- - - Updated - - -
Chuck wouldn'tyou lose1/2 the dia. of the end mill from the raised section of the part? Thus making the raised section smaller than the slot. I don't know as I stated in my first post. my mind is not working good right now. Mark
