I also discovered for myself anyway that if I turn one piece upside down and the other right side up and cut it makes a matching pair for the corner at the same time.
Yes that will also work the only draw back to cutting from the backside on some chippy tiles it will chip more from the backside wich leaves a lil more jagged cut that you have to pick the grout from to have a crisp straight line if I can be of anymore help ask away
