- Jul 20, 2012
- 1,238
I'm installing a backsplash using a rented wet saw. All is well except I need to cut a 90 degree bevel on the small cap tile. On each side to end with beveled edges together. Pieces are about half inch by three eights and the material is fragile.
The bigger tiles cut no problem but when I put the small ones in the 90 degree jig and push through the blade they chip. Tried slow feed. There are a few I need to complete the job.
Is there a tool other than the tile wet saw that might work better?
