- Dec 18, 2019
- 6,464
The screw is a bit too long, I think. Don't have a feeling for this yet, and rather trim it afterwards. Hard to make it longer. The threads in the block can't be longer than 7/8" or so, due to my tap. Honestly still a bit worried about adjustment range still. Version 2 would look a bit different, I'd imagine, but I'm not quite good enough at this visualization stuff to see that far ahead. So plodding ahead with more adjustment than is probably justified. When I get better at this design stuff, I'll learn to make those ranges smaller with a higher degree of confidence.One thought - you really don’t need much adjustment range on the screw-block interface, because it’s for fine motion only. The yoke can slide on the diamond-tool shaft for coarse adjustment. I’d think 1/4” is about all you will ever turn the adjuster. Really much less than that. So there’s no need for the threads to be more than say 3/4” deep in the block (though make the hole through) and about 1/2” on the end of the adjuster. That will make it a lot easier to make.
Also - Composite construction, where you would put a piece of threaded rod in a custom nut, is often a very useful way of making things, to eliminate the need to remove a lot of material.
The good thing about the design is it has both coarse and fine adjustments, which makes it tolerant to screw ups!
