- Jan 25, 2015
- 2,558
I started out grinding my own hss tooling. Was decent, could do the jobs I wanted to with acceptable results.
Tried a carbide insert tool and haven’t looked back.
I will still grind a hss blank if I need a special profile tool though.
I also part with hss tooling. Not that carbide won’t part, I find the hss more effective and more importantly; more forgiving if everything isn’t exactly perfect. I also find carbide parting tools very limited in depth of cut. The ones I’ve tried you essentially get the length of the insert for the cut and not much more. I usually use the carbide cut off tool for grooving instead of parting.
