Etard,
The Gingery books are a great source of information. They have all the needed information to build the machines and the detail is great. There is one small error in the mill book or at least the one I have. I bought the whole series back around 1985 or so. As I recall the error was in the dimensions of the spindle bearing cap or slide. Once you are aware of the error you can easily adjust the pattern build the right way. In all the books I have from Gingery, that's the only mistake I've found.
Years ago I built the lathe. That worked quite well and I had a lot of fun with it. I eventually sold it after buying a bigger lathe.
My suggestion is start with one of the foundry furnace books, you'll need a way to cast your patterns. The book progression starts with the lathe, then the shaper, and finally the mill. You use the machine you just built to machine the parts for the next machine. I skipped the shaper but will go back and build it simply because it looks like a fun machine to build and use.
Dan
