- Apr 8, 2013
- 1,982
My lathe is a G4003G. My fixture was 18 inches long because I had to machine the ends of the fuel rails on my boat engines. Your's could be shorter. A way to drive the PVC without squashing it is to use a big hose clamp. You can make the clamp as tight as you want then use the hose clamp screw housing as a lug to drive the part.Epanzella - That could work as long as I don't need the steady rest, which is too small on my lathe for the 6.3" OD I'm working with. I found that the 4 jaw distorted the plastic some if it was held tight enough to not slip (although I was gripping internally). Maybe I need 6 screws to avoid that. It looks like our lathes are similar looking from that photo anyway. I have a G0509G. What is yours?
