- Nov 23, 2014
- 2,606
I can comfortably put a 20" long part in it. It did not come with a cabinet light so I mounted a flourescent desk lamp inside. HF does not sell replacement disposable sheets for protecting the inside surface of the window. I had a bunch of 1/8" clear vinyl and use that for protectors. Use a couple of old screen door latches to secure the sheets. I also have a water filter right at the blaster. Otherwise it was trying to throw mud, really had a lot of moisture in my air. It works fine for my needs. I have a Campbell Hausfeld 4 HP 20 gallon compressor rated at something like 9 CFM at 100 psi. Picked up the blaster with one of the 25% off coupons so it was around $80.Bruce,
I am thinking of getting the Bench top model also.
How good is it and whats the biggest size part it can handle comfortably?
Bruce
Bruce
