It should be obvious to any competent electrician, that L!,L2, and L3 would connect to the output of the phase converter, along with a ground wire attached to the housing ground terminal; The keyed switch appears to be in the on position, I assume that it would be connected to the control circuit of the magnetic starter, if it is not in the on position, the switch likely could be simply jumped.
