Help With Powered Hacksaw Blade
Which one would be best?
  • http://www.grizzly.com/products/202-3-4-x-1-x-035-x-10-TPI-Raker-Bandsaw-Blade/H4346
  • http://www.grizzly.com/products/101-x-1-x-035-x-10-TPI-Raker-Tool-Steel-Bandsaw-Blade/G8795
Results are only viewable after voting.
Dad & I built a power hacksaw many years ago that used a 12" long blade. He set up the blade holders with two different size screws. One size 8-32 for a typical 1/2" x 12 hacksaw blade and 1/4-20 for a 1" x 12 blade. The 1" x 12" blade was made from cut up bandsaw blade with about a 10 or 12 tooth. Holes were punched using a Whitley hand punch. And yes, bandsaw blade does work just fine!
That is good to know. I had thought that blades made from my thick bi metal Starrett blades might be o.k.,if you can get the curve out of them.
It was said that Grizzly blades were junk. So where do you get the best blade for the buck?
Last ones were Starrett blades. Used to use Morse blades and Lenox. I try to stay away Asian stuff but here lately that's all I can find
Wholesale Tool has the best price I've found - I need to order more of the same size (14 x 1 x .050). They have HSS blades for $4.25 each http://www.wttool.com/index/page/pr...oduct_name/WT+High+Speed+Power+Hacksaw+Blades and Red Stripe for $10.15 http://www.wttool.com/index/page/pr...rett+Redstripe+High+Speed+Power+Hacksaw+Blade. They also have Morse in 10 and 14 tooth for around $15-!18 each. I've broken more than I've wore out - I'm learning what I can and can't cut on my saw, sometimes the hard way!
I have a power hacksaw that uses 14" blades and have quite a lot of them NOS; what width and depth of blade does your machine take? I think mine are 1 1/4" in depth and various tooth pitches, I would be willing to sell you some at a good price; contact me at
York@napanet.net
John York
How did it break? If it tore straight thru the blade from top to bottom, mayhaps you could silver solder it back together. A link to Tom's Techniques has a very good video on silver soldering broken bandsaw blades to repair them. I have built the jig he shows and after a couple failed attempts to tig weld my broken blade back together, I soldered it and then cut it apart a couple more times and resoldered it back together for the practice. Good luck
Nodak Gary
Nodak Gary
I like this idea. I may try it. I need to get some silver solder. It isn't straight but I may be able to shorten it a bit to make it that way. I don't really remember right now what it looked like.
Solder is another topic I don't know much about. I solder electronics & have done some in plumbing but never tin/steel parts.
Hi kingmt01,
I have never heard of using bandsaw blades on a power hack saw.
On my power hacksaw the blades are substantially thick.....but the whole machine is way bigger than I've ever needed.
A thicker (stiffer) blade will wander less.
I wonder about any design differences(maybe tooth set?).....hacksaw blades travel backwards in the kerf, bandsaw blades do not.....typically.
I believe the blades should have hardened teeth on a softer band, but how soft is the question.
Did it get hardened some by the (likely) induction hardening of the tooth edge?
Is it soft enough to drill?
I do remember seeing a way to "spot temper" a piece of thin hardened stock. I believe it was in this book:
http://www.amazon.com/Complete-Mode...48&sr=8-1&keywords=complete+modern+blacksmith
It went something like this:
-cut the head off a nail
-chuck the nail in a drill press (flat end down)
-spin the nail against the workpiece at the point you want the hole
-when it gets red hot place it into a bucket of ashes or insulation to cool slowly
-when cool you should be able to drill it
I'll try to double check the book when I get home tonight, and repost if there's any substantial difference.
-brino
You can heat the nail with a torch and then press it against the blade, too. But I prefer the drillpress method: less chance of error. And I use a bucket of granular limestone (not the powdered stuff, which is messy) for "controlled" cooling.
PeteH
