The saga continues ...
One of my recent quests has been to buy some new grinding wheels. The first photo below shows the sad condition of the 120 grit wheel that came with the grinder.
There seem to be two very popular styles of wheels - unobtainable and overpriced. Very few suppliers carry this style any more, and for many of those who do, their prices can run to well over $150 or more per wheel! As I'd paid only $225 for the grinder itself, this was a bit much for me. [Yes, I know the adage - you'll generally pay as much for tooling as for the original machine tool ... but I'm on kind of a tight budget nowadays]
Then I got lucky. An Israeli company, Camel Grinding Wheels (CGW) sells this style of wheels through Travers Tools
http://www.travers.com/ Travers retails through Amazon and eBay. They want about $51/wheel. I ordered three through eBay, and Travers was nice enough to combine shipping and save me about half.
Then I was talking with a friend of mine (and member to this forum), Rick Sparber. He owns a Harbor Freight clone of the Baldor. Turns out he'd ordered two wheels for it a while ago, but the hole pattern did not match. The supplier refunded his $ and told him to just keep the wheels. Rick was nice enough to charge me his cost - zero!
It turns out that the CGW wheels he'd purchased fit perfectly on the Baldor - so it's the HF grinder that has an odd bolt pattern! The first photo shows one of the wheels mounted on the grinder, plus the original used up wheel and my spare aluminum oxide 46 grit wheel. The arrow in the photo points to the "field expedient" lamp shade I added to an LED bulb in the gooseneck socket. The original lamp shade was badly broken.
The second photo illustrates how I fixed a runout problem on the wheel mount plates. Both of them had about .006" surface runout. It turns out that Scotch "Magic" Tape is .002" thick. So I set the indicator's zero at the high spot, rotated the wheel until it was .002" low, added a piece of tape, went around to where it was .004" low and gave it two layers, etc.
Finally, I wanted to replace the missing water catch trays. Baldor has them for about $80 each. But Grizzly sells a similar grinder, the H7762. And their trays, PH7762022, are under $15 each. I called their help line to check on the hole spacing and it sounded like they would fit. So I ordered a pair. They arrived today - fit PERFECTLY! Both the hole diameters and hole spacing are right on.
Just for paranoia's sake, I drilled and tapped into the end of one pin and added a #8 screw. Now I know that the trays won't walk off if there's any vibration.
About all I have left to do now is to fabricate a tool support, per Rick Sparber -
http://rick.sparber.org/ngc.pdf
